Probleme mit HAM V90 Modemtreiber unter SUSE 7.1
(Anonym) / 0 Antworten / Baumansicht Nickles
Habe bei Intel einen treiber für mein Creatix HAM intern Moden runtergeladen und erhalte bei der Installation folgende Fehlermeldung:
linux:/opt/modem/release # make clean
cd src/hamcore; make clean
make[1]: Entering directory `/opt/modem/release/src/hamcore\'
rm -f *.o *~ core
make[1]: Leaving directory `/opt/modem/release/src/hamcore\'
cd src/serial; make clean
make[1]: Entering directory `/opt/modem/release/src/serial\'
rm -f *.o *~ core
make[1]: Leaving directory `/opt/modem/release/src/serial\'
rm -f ham.o
rm -f hamcore.o
linux:/opt/modem/release # make all
cd src/hamcore; make hamcore-release
cc -Wall -O -I /usr/include -I../inc -c -o coredrv.o coredrv.c
cc -Wall -O -I /usr/include -I../inc -c -o clmmain.o clmmain.c
cc -Wall -O -I /usr/include -I../inc -c -o rts.o rts.c
rts.c: In function `RTS_Enable\':
rts.c:94: structure has no member named `next\'
rts.c: In function `RTS_Task_Schedule\':
rts.c:239: `tq_scheduler\' undeclared (first use in this function)
rts.c:239: (Each undeclared identifier is reported only once
rts.c:239: for each function it appears in.)
rts.c:246: warning: passing arg 1 of `__wake_up\' from incompatible pointer type
make[1]: *** [rts.o] Error 1
make: *** [all] Error 2
linux:/opt/modem/release # make install
bash haminst
running kernel 2.2.18
installing
hamcfg
hamtool
hamdata
serial module
install: cannot stat `ham.o\': No such file or directory
core module
install: cannot stat `hamcore.o\': No such file or directory
SuSE version 7.1
SuSE 7.1 boot scripts
starting module and utilities
insmod: hamcore: no module by that name found
done
kennt irgendwer das problem? mögliche Lösungen?
